Quick Question about installing!!!
wire all coils together in a 1 ohm load + to + and - to - and bridge to the amp
in that pic hot goes far right negative goes far left ... and btw that hifonics will do 1500 rms at 13.4 volts.
95 Civic Coupe
Pioneer AVH-P7600DVD
Kinetik HC-1200 In Front
Kinetik HC-2000 In Rear
Memphis 16-MCA3004
2 X Memphis 16-MCD1000 With Maxxsonics MLX-100
2 X DC LVL 4 XL 12's
Pioneer Premier TS-C720PRS In Door's
Kenwood KFC-6982ie In Rear Deck
All Memphis Wire/Rca's and misc.
you can't bridge a mono amp bro ^^^^
they two positives are internally connected
and the two negatives are internally connected
you can hook up the positive to either one of the positives and you can hook up the negative to either one
it just has 2 for both for ease of wiring, most mono amps are like this
I have the same amp, and from what i got from the manual was that you should use the + and - on the right.
RE SE 12" subs (2) in prefab dual ported box (custom box coming soon)
Hifonics bxi610 mono 600 watt amp
Stock HU
Mach RCU
Apline 5 x 7 S Type Speakers (2) (1 blown)
Stock rear speakers (2)
Pyramid Tweeters (2)
Look at the pic. the positives are next to each other and the negatives are next to each other. They are connected internally for ease of wiring multiple subs (2 dual 4's for example).
If you have 2 dual 4-ohm subs, wire each sub down to 2 ohms and connect them to the amp and it'll be wired to one ohm.
15.4" widescreen
128MB shared video memory
Windows 7 Home Premium 64 bit
What it does:
On a USB 2.0 Wireless card
Sweet thats how i have it hooked up at the moment thank you guys
  • Who's Online   0 Members, 0 Anonymous, 368 Guests (See full list)
