Indyballin Posted November 30, 2009 Report Posted November 30, 2009 I just picked up a Alpine CDE-102 Head Unit and i hooked it up to a Brutus 1610-D and a spl 12" but my problem is every thing works when i use the tuner but i have no mids or highs when i switch to a cd its all in my 99 Durango using a wiring harness i picked up at autozone. thx for the help
maniac74 Posted November 30, 2009 Report Posted November 30, 2009 I just picked up a Alpine CDE-102 Head Unit and i hooked it up to a Brutus 1610-D and a spl 12" but my problem is every thing works when i use the tuner but i have no mids or highs when i switch to a cd its all in my 99 Durango using a wiring harness i picked up at autozone. thx for the help make sure on your hu the remote wire is hooked up to the right output. power antenna is wrong, remote power is right both r blue. , i made the same mistake when i used the harness on mine. what happen's is when your on tuner mode it sends power through the power antenna wire if you had a power antenna and when you switch to cd mode it shuts the 12v off cause the antenna is not needed on cd or ipod. get what i'm sayin. 99 suburban 20" boss motorsport wheels big 3 installed (thanks Iraggi) alpine 9886 deck kenwood 11 band eq fosgate t5002 amp running sub kenwood ps200 amp running components jl xr components in front doors jl xr 6.5 in rear doors jl in rear roof 1 FI Q 18" with bp enclosure 8 cubes 138 sq" port 34hz Iraggi 220 ho alt (RF 1500bd coming soon)
Indyballin Posted November 30, 2009 Author Report Posted November 30, 2009 Right on ima try it right now
