looking for a high output alternator
i have a 2004 lincoln navigator and ive been doing research on a high out put alternator and im not sure with one to choose. so here it goes my choices are as follows;
power master 220 amp, d.c. power 260 amp, xspower 250 amp and a 260amp Irragi Alternator i cant seem to locate 1 with a higher output should i go with 1 of these or should i go another route???
i have 2 15inch fully loaded btls on a lanzar opti 6000d and a lanzar opti 400x4hc ( for my loud speakers) and a kenwood for my tweeters.
please advise and thanks in advance fellas!!!
Guest DC Power Kyle
You also need to look at it from the "at idle" perspective. Would you rather want to rev your engine to keep your voltage up or being able to slam your system at idle? If you're truly looking for something that you need to rev we can build bigger than 260 amp alternators for your vehicle. It just depends on the money you wish to spend. If you would like, PM me your budget and we can go from there.
Iraggi also has a brand new 320 that does around 160 at idle and close to 200 with our overdrive pulley. It really depends on your engine idle rpm and crank pulley diameter. Those numbers are typical tho. The 320 is $80 more than the 260 if you already have pricing on the 260. :)
Thanks,Dom
  • Who's Online   0 Members, 0 Anonymous, 801 Guests (See full list)
