dcsoundlabMN Posted December 21, 2009 Author Report Posted December 21, 2009 yeah just make sure your putting 2.5k and not 2.5k +clipping alrite what exactly is clipping and how do i make sure it doesnt happen (newb here) Quote 02 Chevy Trailblazer 18" DC XL build in progress... refs: ak1167 (bought tweeters from)
dcsoundlabMN Posted December 21, 2009 Author Report Posted December 21, 2009 and again, box materials? glue? bedliner? bracing? what should i need Quote 02 Chevy Trailblazer 18" DC XL build in progress... refs: ak1167 (bought tweeters from)
dcsoundlabMN Posted December 21, 2009 Author Report Posted December 21, 2009 alrite what exactly is clipping and how do i make sure it doesnt happen (newb here) Quote 02 Chevy Trailblazer 18" DC XL build in progress... refs: ak1167 (bought tweeters from)
brewer_brewer Posted December 21, 2009 Report Posted December 21, 2009 (edited) think of clipping as massive distortion. it makes ALOT of heat and will toast any sub if you don't know what you are doing. you could blow that sub with 1000 clipped watts easily. so you better be damn sure that those "2500" are clean as hell. you will be probably only see 2200 out of the AQ and i would suggest finding someone with an oscope to set up your amp properly here is somewhat of a guide to give you a better idea http://www.stevemeadedesigns.com/board/ind...?showtopic=4382 Edited December 21, 2009 by brewer_brewer Quote REFS http://www.caraudioclassifieds.org/forum/itrader.php?u=2026 http://www.stevemeadedesigns.com/board/topic/44535-official-brewer-brewer-feedback/page__p__625998__hl__brewer__fromsearch__1entry625998 "you're not allowing natural selection to work, you're like the guy that invented the seatbelt"
dcsoundlabMN Posted December 21, 2009 Author Report Posted December 21, 2009 clipping is when the amp puts out dc volts instead of ac volts.it makes ALOT of heat and will toast any sub if you don't know what you are doing. you could blow that sub with 1000 clipped watts easily. so you better be damn sure that those "2500" are clean as hell. you will be probably only see 2200 out of the AQ and i would suggest finding someone with an oscope to set up your amp properly here is somewhat of a guide to give you a better idea http://www.stevemeadedesigns.com/board/ind...?showtopic=4382 is it mostly to do with the way the settings on the amp are set? or jus not enough juice or what is it? Quote 02 Chevy Trailblazer 18" DC XL build in progress... refs: ak1167 (bought tweeters from)
brewer_brewer Posted December 21, 2009 Report Posted December 21, 2009 both. too much bass boost can cause clipping, not enough input voltage, bad signal from your source, gains set to high, or any combination of those put together. Quote REFS http://www.caraudioclassifieds.org/forum/itrader.php?u=2026 http://www.stevemeadedesigns.com/board/topic/44535-official-brewer-brewer-feedback/page__p__625998__hl__brewer__fromsearch__1entry625998 "you're not allowing natural selection to work, you're like the guy that invented the seatbelt"
