5.5-6ft3 @ 34hz w/ 70-80in^2 of port area per pair of woofers is my box suggestion.
1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN.
Pioneer AVIC-N2
(12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each
Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s
26ft3 @ 33hz w/ a ton of port area
156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace
the less port area you have, the easier it is to tune low. BUUUT you run the risk of having port noise which is super annoying and sounds like balls.
the more port area you have (always aim for 12-16sqin per cubic foot), its a little harder to tune lower but the performance is better as far as moving air around.
how is it harder to tune?
do you use this rule for the gross volume or the net volume
  • Who's Online   0 Members, 0 Anonymous, 8227 Guests (See full list)
