3500 per btl would be plenty power for good results, there are a ton of people running aq amps too. Plenty of bang for the buck.
:drinks: thanks man thats all i was needing some guys who know more about them then i do i.e. (i just read online stuff) sry if my ?'s seem noobish or stupid.. :sad:
*2013 NEW BUILD*
12- 18" Crossfire XS v2's B pillar 4th order wall
4- Crossfire 8K mono blocks
40+ pro audio mids tweeters and horns
3- Singer alternator 400a external regulated alts
tons of audiotechnix wire
24- XS Power D1400's
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
its all good, sorry for comin off the way i did. But those amps would match up just fine with a fully loaded btl. should see some good results :)
4 15" dc audio level 4 xl's in 4th order blow through
2 IA 40.1's at 2 ohms strapped with 3.9 rise...currently own 4 IA 40.1s.....
1 06zx3504 running Kicker QS 6 1/2's
1 iraggi 180 amp alt
1 optima d34 yellow top under hood
5 deka intimidators
HU - Eclipse AVX5000 W/ DCU-105
Termlabed 157db at 38hz 6000 watts
definitely a legit question man some people just think that if they know something then everyone else should know it to. I believe if I remember correctly, that meade was able to put so much power on his BTL's due to some factors like it was totally clean power as well as the spec of his box. Not sure exactly but its something about port area vs cu ft per sub and how it controls the cone. I know BTL's can take a lot though so I think with the right electrical you would be fine with a 3500 on each. AQ is the sister corp of DD so you know they are well built and good prices too.
i think i just gave myself a concussion i facepalmed so hard.
and for the 1's that dont like me.....
well, Im still here fuckers. Cant get rid of me that easy.
thanks man iv been without a system for a while tryin to sketch up a few ideas and came up with this... i realy hope to get some good results! :clapping: sick of spending a ton of money and never being enough
as i said i may go with some of the RD H.W. series ? if i can find out some more about them i just know that FI seems to be the way to go for me as of now...
*2013 NEW BUILD*
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
steve meade was also able to run so much power because he knew his limits. Btls will take a crap ton of power like that, but only in certain amounts of time. Just gotta know its limits, as with any other piece of equipment.
5 deka intimidators
yea its cool man i think it was more less a misunderstanding... and as for my box, like i said Jack (aka the sleeper builder) will be designing my box when its time so id say the box will be well designed! :give_rose: a privilege to have him help with my build/ design
*2013 NEW BUILD*
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
Lol good shit man, I watched some vids of his sleeper and it DESTROYED the lows. Hope the design he does for you works out just as good.
btl's are nice but the aluminum coil HDC3's are really nice too. to be completely honest there are so many brands out there that for the most part have a woofer than can compete with each other so you just have to pick the brand that you like best. DD, FI, RE, RD, DC, AQ, cadence, american bass. Ascendant audio i could go on for a while lol. and Yes those amps would power the btls nicely BUt your going to need more electrical than what you stated above. hope this helped somewhat :)
2005 Ford Ranger Reg cab
Build in Progress
T3 Audio T2000 12
ARC SE4000
Stinger HPM 1/0 Wire
DC power 270xp
Batts: 1 Redtop up front and a Stinger SPP2250 in the back
Hopes to be in and around a 150....weel see
my youtube channel
http://www.youtube.com/user/steph3n1
Team DBs (Driven By sound)
yeah ill prob be sticking with the FI's.. and the AQ amps
as for the electrical, i talked to dom and he said i could have a good charge on a 8 batteries, so the 5 powermaster batteries i stated above and the 2 stock diesil batteries (i changed out to bigrig "semi" batteries) that will make 7 total and each amp will have 0g them along with each battery receving 2 pos and 2 neg runs and i have already upgraded the charging wiring from the alts..
if i can get 2 of dom's 320a HO alts on my truck which we are working on (my dad has a fab shop) then ill add a few more batteries to my bank and have... lets just say atleast 8 D3100's thats 2 per amp and 2 D1800's just extra and for the highs amps
so if i can get that second alt on id have:
(2) 320a HO iraggi alts
(8) powermaster D3100's
(2) powermaster D1800's
(2) interstate semi batteries
and around 250' of 0g.
what about that? and like i said this build is not in a hurry... i am taking my time and making sure i have what i need :D and thanks for the input!
*2013 NEW BUILD*
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
  • Who's Online   0 Members, 0 Anonymous, 1010 Guests (See full list)
