1985 Buick Regal Limited Build Log
Since I will be molding the under side of the trunk I picked two of these up:
A real rough idea of how it will sit in the trunk on one side:
Firm believer in letting my cars do my talking!
You can't rush quality, it doesn't happen overnight. Quality takes time and dedication, but the end results more than pay for it.
"Black Pearl" Build Thread
http://www.stevemeadedesigns.com/board/topic/67183-1985-buick-regal-limited-build-log/page-1
Another productive weekend...so on with the progress pics!
I started be sandind off all the old fleece:
After that I CA glued the grille clothe to the side of the dash:
Then it was on to the resin:
I didn't want a 90 degree turn on the dash so this was my means of rounding the corners on it:
I used the rounded cut on the spatula to lay down filler:
After it was sanded down:
And after that I hit a couple spots on the dash with filler, knocked it down, and then gave the entire dash a thin coat of "milkshake"
All I had left was the entire underside of the frame to mold so I got to it:
After I finished that up I went to spot weld:
An idea of how much grinding was done
Custom machined trunk emblem
Before
Finished
Finished molded frame
sanded down the MDF frame I put in the dash bezel so it is nice and flush now. Just need to get back and glass it in fully:
And finally got around to sanding down the "milkshake" I had applied to the dash:
Headrests:
Suede armrests for front and back:
Since the space in the g body trunks is at a premium and with 9 batteries, a piston pump, and 2 regular pumps going in there already I was looking for other options. Well, problem solved:
Alpine PDX5. Much smaller than even one of the RF amps at does the following:
75 x 4 and 300 x 1 mono
Birth sheet on the amp has it rated as follows:
105 x 4 and 367 x 1
So I am looking forward to hooking that beast up and seeing how it sounds
That is basically where the build sits as of now. I am still working on the dash/interior panels and will begin to get back on sealing/painting the frame here soon I hope.
I love that body style Regal. You have done alot of good work. I can't wait to see it finished.
2000 VW Jetta
Pioneer headunit
1 Soundstream PC.6 6.5" component set
4 Pioneer TSA6984R 6x9
4 Selenium 6w4p 6"
2 15" Sundown Audio E's in 4 cubes @35hz
Digital Designs CM1000
Rockford Fosgate Punch p400.4
Plans
New Box
New headunit
New Amps
R.I.P.1995 Chevy Blazer LS
Rockford Fosgate headunit
2 Rockford Fosgate T1 6.5"
2 Rockford Fosgate T1 4x6
2 Rockford Fosgate T1 4"
Hifonics Warrior hcx5.2c
4 Selenium 6w4p 6"
18" Mmats Juggernaut in 4.5 cubes @ 27hz
Hifonics Brutus 1200
Alpine 4 channel
Optima Red Top
Plans
New Box
New headunit
New Amps
Thanks. I appreciate it. I have always liked the g bodies, but it is all personal preference. I am shooting to have it done this summer, but with the birth of my wife and I's first child progress has been haulted a little. But getting back into it slowly but surely!
  • Who's Online   0 Members, 0 Anonymous, 1155 Guests (See full list)
