Need some pro's help and opinions.
Ok I will soon be buying my BL 18 when income tax comes in, and I've been using exposports box calc. ALOT coming up with designs and I think I found the best one so far. I just wanna know you guys' opinion that know more about this stuff than myself. Ok, box external dimensions are 46W x 26H x 16D and i got a gross volume of 8.56 cuft. Slot port internal dimensions are 14H x 6.5W x 15L, and including the 0.26 cuft sub displacement i got a net of 7.46 cuft tuned to 33.16. How does this sound, it should definately LOVE the lows yet still play clean highs and get LOUD (hopefully close to 140ish???). Oh yeah and the box is sub forward port up on the driver side, and for bracing I'll use 1" dowels to save some space and the front will be double baffeled with a countersunk sub. Material will be 1" MDF
a0xp5g.jpg-2 AQ HDC3 15's-'Nendo 3KWP @ .5-7.75cuft @ 30hz-Alpine CDA-117-4 Cadence PA 8's
-AQ 200.2-2 AQ Supertweeters-XS Power D3400-270a Mecman Alt
-Knu Konceptz Wire
Sounds to me like you have a good solid start, and you're not expecting ridiculous numbers. Good on you.
The design sounds good. In my opinion though, I would try both your idea and also sub up port sideways to see which yields a better sound. Should pound nicely. I wouldn't be surprised with that setup hitting a 140.
Need an install? Hit me up.
[email protected]
Got car audio questions? Check here first!
Everything you need to know. =]
http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
Yeah i hate it when a noob thinks they can just buy an 18 and slap a box together and hit 160! lol
But when you say port sideways you mean facing either the driver or pass. side of the truck right?
-Knu Konceptz Wire
Depending on the position yes. Hell, I would try all three if your design allows. It's all trial and error and you might just be surprised with the result!
[email protected]
I'll will most likely do all 3 and try them on my buddies TL, but for now im gonna build the said box of one that someone else designs if they do and run with that for a while. I'm just to get away from a Sony Xplod 10 and .65 cuft sealed box....... lol (came with my truck back when i bought it btw... not my doings!)
-Knu Konceptz Wire
i think your ports wrong. if your box is 16" deep (you must not be tall because in mine 15" is max i can go. lol) and if your box is 16" deep, port up, your port would be 14.5" (.75" on each side for the wood) unless your using 1" mdf. but the 18 will do nice in there, dont port sideways, its only good for smaller box's. sub forward, port up!!
Edit: sorry just re-read, you are using 1" MDF lol.... carry on hahaha
Edited by Hostility
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
3 Sundown Audio SA-12's
Alpine H/U
RF Power Comp set 6.5"
RF 3 sixty line driver
5.25 cubes @ 31hz
lol :01nocomment8so: on the height... i like being closer to the dash anyway and i already measured and i should be comfortable in it.
And yeah im using 1"MDF
-Knu Konceptz Wire
haha yea, i drove up close for a while, hurt my back and i didnt like it, my new box will be 14.75" depth, so hopefully it will be better haha, also you must have a 3rd door to get 46". i can only get 43" with no 3rd door. it sucks!! plus getting big box's in and out, i have to remove my passenger seat and struggle with them.
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
Alpine H/U
5.25 cubes @ 31hz
Yeah luckily i got the 3rd door which help ALOT, and as far as seat placement goes it will be a little close but i surprisingly have enough room to lay my seat back quite a bit. My buddy is 6'1" and he can still fit in it, a little cramped of course, with a mock up cardboard box we made.
-Knu Konceptz Wire
ahh nice, good idea!
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
Alpine H/U
5.25 cubes @ 31hz
  • Who's Online   1 Member, 0 Anonymous, 1491 Guests (See full list)
