Gingeriffik Posted January 28, 2010 Report Posted January 28, 2010 I got a question, I alwas thought the point of buss bars was to run less wires. What is the advantage of running a buss bar on the batts. but still running individual wires from the batts to the distribution bar? I am getting ready to begin my new build here in a few months and would like to understand this better. Figured ther would be no better people to ask than the Mead Heads . Thanks, (This would be in ref. to Mr. Meads latest install in the HOE.) <>< Collosians 2:13-14, Philippians 4:13, 1 John 4:7-10 2 - JBL W15Gti 2 - JBL BP1200.1 Knu 1/0 Wiring Kenwood KIV-BT901 Kenwood/Garmin Nav.
Gingeriffik Posted January 29, 2010 Author Report Posted January 29, 2010 BUMP! <>< Collosians 2:13-14, Philippians 4:13, 1 John 4:7-10 2 - JBL W15Gti 2 - JBL BP1200.1 Knu 1/0 Wiring Kenwood KIV-BT901 Kenwood/Garmin Nav.
fritosaregood Posted January 29, 2010 Report Posted January 29, 2010 Batteries only have one pos and one neg bolt hole normally. with a buss bar you can add more spots to bold down wires without having to stack them. You can also use them to connect a bank of batteries. They are also useful as cheaper distroblock. seller feedback: http://www.stevemeadedesigns.com/board/ind...showtopic=61719 http://www.stevemeadedesigns.com/board/ind...showtopic=68281 build log: http://www.stevemeadedesigns.com/board/index.php?showtopic=44800 Gf's build: http://www.stevemeadedesigns.com/board/topic/54346-kickergirls-camaro-new-box-pg-5/#entry753970
Gingeriffik Posted January 29, 2010 Author Report Posted January 29, 2010 I guess my thought was, if you buss the batts. together, you would only need to run 1 from the batt buss to the dits. buss. I sorta realize looking at Meads, I forgot to take into accout that he has 4 alts. Plus there is most likely too much amperage to make a single wire run form the dist. buss to the batt. buss. <>< Collosians 2:13-14, Philippians 4:13, 1 John 4:7-10 2 - JBL W15Gti 2 - JBL BP1200.1 Knu 1/0 Wiring Kenwood KIV-BT901 Kenwood/Garmin Nav.
