Help with SPL Box for my DLS sp12i
Hi, is there anyone that could help me?
I want a box for my DLS sp12i thats going to play loud with music, i don´t have any good program my self.
Woofer size 12" (30 cm)
Impedance 2 ohm x 2
Power handling capacity 500 W RMS
Max power handling capacity 800 W
Peak power 1200 W
Frequency range 20-2000 Hz
Sensitivity 97,3 dB (1W/1m)
Magnet size 220 mm (8,7"), 200 oz
Outer diameter of woofer 313 mm (12,3")
Mounting depth 153 mm ( 6")
Mounting hole 282 mm (11,1")
X-max +- 12 mm (0,47")
Weight 13 kg (28,66 lb)
T/S-Parameters
(in parallel) Fs 43,4 Hz Re 1,1 Ohm Qms 4,43
Vas 27,8 liter Vas 0,98 Cuft Qes 0,27
Qts 0,25 Sd 594 cm² BL 16,3
/Jens
Sponsored by:
www.DLS.se / www.kudoz.se / NPdack.se
Voice coils in parallel: Volume 36,9 liter/1,30 cuft, Port: 3" diameter with length 25 cm/9,84". F3= 30 Hz
Voice coils in series. Volume 40,4 liter/1,43 cuft, Port: 4" diameter with length 17 cm/6,7". F3= 50 Hz
From the DLS website :)
I don't think you're going to find anyone on here that has actually run them. If they're anything like the MW112D they don't like loads of port area.
10.x volts fo' life!
Thanks.
I already had that info and just thought that there could be anyone here that can calculate on SPL boxes.
I have one suggestion thats looks like this:
40liter box, 180cm2 slotport thats 53cm long.
Sponsored by:
Thanks.
WAY too much port area. I would run closer to 60L with 2 100mm aeroports. Then cut the ports until it sounds good to you.
  • 3 months later...
  • 8 months later...
  • Who's Online   1 Member, 0 Anonymous, 1752 Guests (See full list)
