99xtremedime Posted February 16, 2010 Report Posted February 16, 2010 Ok after throwing around many, many designs I finally came up with my final box's dimensions. And instead of doing a slot port, I'd rather do 4 4" aero ports (2 on each end firing up) to save myself a little time. My question is how long would they need to be and should i use bigger tubes? Box specs are 46l x 27h x 15d internal vol. after sub displacement is 8.02cuft and i want the box as close to 33hz as possible. Thanks. -2 AQ HDC3 15's-'Nendo 3KWP @ .5-7.75cuft @ 30hz-Alpine CDA-117-4 Cadence PA 8's -AQ 200.2-2 AQ Supertweeters-XS Power D3400-270a Mecman Alt -Knu Konceptz Wire
