uhoh_45 Posted February 17, 2010 Report Share Posted February 17, 2010 yeah i'd put some fans in there just to get the air circulating and i dont think that headliner helps next time you play em and you notice they are gettin hot check the headliner see if its holding the heat R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log Link to comment Share on other sites More sharing options...
Bunker Posted February 17, 2010 Author Report Share Posted February 17, 2010 yeah i'd put some fans in there just to get the air circulating and i dont think that headliner helps next time you play em and you notice they are gettin hot check the headliner see if its holding the heat Headliner doesn't hold heat from the top of the amps is has about 10in to the headliner. J&T DESIGNS M5 4 Audioque 15's copper coils dropping Audiopipe, and picking up DB DRIVE OKUR Powermasters XS POWER Dropping MaxxSonics Pioneer Link to comment Share on other sites More sharing options...
Loudcivic Posted February 17, 2010 Report Share Posted February 17, 2010 i have a few of these and they are adjustable so it makes it kinda nice and they put out 110cfm at full blast. they move a lot of air and work great for me. stick with the 120mm fans they do pretty good on cfm and at the same time can be quiet doing it. they are worth the money and will help out a lot http://www.newegg.com/Product/Product.aspx...N82E16811999344 2015 silverado crew cab nothing atm but soon... Link to comment Share on other sites More sharing options...
