Gutta Trash Posted February 21, 2010 Report Posted February 21, 2010 I am going to be wiring 3 subs at a 1.34ohm load which will require daisy chaining speaker wire, and I would rather not use the terminals to do it because it would cause me to have to use smaller wire. Does anyone know where I can get 3 way wire splicers/connectors that can be soldered? Quote On 4/20/2010 at 10:06 PM, 'cc_audio' said: Guys are just like girls, once you've had 18 inches you don't go back. 2004 GMC Yukon XL Pioneer AVH-X4700BS 13 band EQ Sub Amp- (2) PPI 5000BD.1 (2) Re SXX 15's 8 cu. ft. box tuned to 32 Hz (4) 6.5 Bose Mids (2) 1" Bose Tweets (2) 1.5" Bose Tweets (1) JY 80 AH w/ new JY busses (1) Duracell 750 up front Apex Alternators 270 A.C. Delco 160 alternato
Gutta Trash Posted February 21, 2010 Author Report Posted February 21, 2010 bump bump BOOM! Quote On 4/20/2010 at 10:06 PM, 'cc_audio' said: Guys are just like girls, once you've had 18 inches you don't go back. 2004 GMC Yukon XL Pioneer AVH-X4700BS 13 band EQ Sub Amp- (2) PPI 5000BD.1 (2) Re SXX 15's 8 cu. ft. box tuned to 32 Hz (4) 6.5 Bose Mids (2) 1" Bose Tweets (2) 1.5" Bose Tweets (1) JY 80 AH w/ new JY busses (1) Duracell 750 up front Apex Alternators 270 A.C. Delco 160 alternato
Guest Posted February 21, 2010 Report Posted February 21, 2010 i dont see why you cant wire them like that with short separate pieces of wire. most woofer terminals are fit to size 8-10 gauge wire. you COULD use bolts as the box terminals and hook up all the speaker + and -'s to the bolts and wire to your amp accordingly Quote
Gutta Trash Posted February 21, 2010 Author Report Posted February 21, 2010 i dont see why you cant wire them like that with short separate pieces of wire. most woofer terminals are fit to size 8-10 gauge wire. you COULD use bolts as the box terminals and hook up all the speaker + and -'s to the bolts and wire to your amp accordingly that's exactly how I'm gonna wire them I just want the best possible connection and at the terminals wouldn't give me that. The bolt idea is a good idea though I may use that if I can't find a soldering solution. Thanks for the input Quote On 4/20/2010 at 10:06 PM, 'cc_audio' said: Guys are just like girls, once you've had 18 inches you don't go back. 2004 GMC Yukon XL Pioneer AVH-X4700BS 13 band EQ Sub Amp- (2) PPI 5000BD.1 (2) Re SXX 15's 8 cu. ft. box tuned to 32 Hz (4) 6.5 Bose Mids (2) 1" Bose Tweets (2) 1.5" Bose Tweets (1) JY 80 AH w/ new JY busses (1) Duracell 750 up front Apex Alternators 270 A.C. Delco 160 alternato
TeejayBee Posted February 21, 2010 Report Posted February 21, 2010 goggle goggle goggle hahahaha i had to bro dont hate ! Quote
Gutta Trash Posted February 21, 2010 Author Report Posted February 21, 2010 bump Quote On 4/20/2010 at 10:06 PM, 'cc_audio' said: Guys are just like girls, once you've had 18 inches you don't go back. 2004 GMC Yukon XL Pioneer AVH-X4700BS 13 band EQ Sub Amp- (2) PPI 5000BD.1 (2) Re SXX 15's 8 cu. ft. box tuned to 32 Hz (4) 6.5 Bose Mids (2) 1" Bose Tweets (2) 1.5" Bose Tweets (1) JY 80 AH w/ new JY busses (1) Duracell 750 up front Apex Alternators 270 A.C. Delco 160 alternato
kx519 Posted February 21, 2010 Report Posted February 21, 2010 goggle goggle goggle hahahaha i had to bro dont hate ! You spelled that wrong. Maybe you should google how to spell google. Quote 84 K5 Blazer 3" body, 2" Suspension 35" Maxxis Bighorn 100amp Alt Marine deep cycle for the amps (freebie) KnuKonceptz 1/0 8 Hifonics HFi 12D4's in ~19cubes tuned to 35hz Audiopipe AP-18001D RF 5x8's in the kicks Almani 5.25 comp. in back Kenwood KAC-645 --IN THE FUTURE-- None. <!--quoteo(post=0:date=Feb 3 2010, 09:12 AM:name=Decaf)--><div class='quotetop'>QUOTE (Decaf @ Feb 3 2010, 09:12 AM)</div><div class='quotemain'><!--quotec-->we seriously need some butt plugs so you guys stop spewing chit talk<!--QuoteEnd--></div><!--QuoteEEnd-->
Gutta Trash Posted February 22, 2010 Author Report Posted February 22, 2010 lol Quote On 4/20/2010 at 10:06 PM, 'cc_audio' said: Guys are just like girls, once you've had 18 inches you don't go back. 2004 GMC Yukon XL Pioneer AVH-X4700BS 13 band EQ Sub Amp- (2) PPI 5000BD.1 (2) Re SXX 15's 8 cu. ft. box tuned to 32 Hz (4) 6.5 Bose Mids (2) 1" Bose Tweets (2) 1.5" Bose Tweets (1) JY 80 AH w/ new JY busses (1) Duracell 750 up front Apex Alternators 270 A.C. Delco 160 alternato
TeejayBee Posted February 22, 2010 Report Posted February 22, 2010 firefox failed and said it was spelt right >.< Quote
