Dan208 Posted February 23, 2010 Report Posted February 23, 2010 I've got an MTX RFL600D with a bass knob. The settings are as follows: Gain: 5V-.25V Subsonic: 25Hz-50Hz Bass Boost: 0dB-12dB LPF: 40Hz-200Hz Now my question is, in what order do I go about adjusting the settings? According to the manual, for the bass knob you turn the gain all the way down and the bass knob all the way up. Then you adjust the gain up to the final non-distorted level and adjust the knob for best performance. So where do the other settings come into play? Do I adjust those after adjusting the bass knob, or before? I've never had an amp with a bass knob, so I'm kind of lost at exactly how to use it. Feedback thread- http://www.stevemeadedesigns.com/board/topic/70871-dan208-feedback-thread/page__p__981961__hl__dan208__fromsearch__1entry981961
thebiggmann12 Posted February 23, 2010 Report Posted February 23, 2010 turn ur ssf all the way down, since u have a sealed box. bass boost off, set ur gain with ur bass knob not connected, then when u connect it turn it all the way up and u will be where you set ur gain. turning it down will turn down the gain. lpf should b around 60-80 depending on your preferences.
Guest Posted February 23, 2010 Report Posted February 23, 2010 most simplistic instructions right here Gain: use a volt meter and find the thread on how to tune gains properly on here (search function, use it) to find how much you need to turn that little knob Subsonic: set to whatever the tuning of the box is if its ported, if sealed, set to probably 30hz or something (i dont remember if woofers stop themselves from overexcurting when in a sealed box) Bassboost: keep it off/0 LPF: 80-100hz
t-money Posted February 23, 2010 Report Posted February 23, 2010 what kind of box and what kind of head unit 2002 ford focus hatch pioneer DEH-P8400bh infinity kappa 6.5 components front and rear XS Power D1200 Shuriken BT-100 audioque 120.4 2 15 inch audioque HDC3 D2 2 audioque 2200d big 3 mechman 220a alt with external regulator 479-418-3056
Dan208 Posted February 23, 2010 Author Report Posted February 23, 2010 what kind of box and what kind of head unit Sealed box with factory HU. I was just reading the thread on tuning. I need to get my hands on a voltmeter. Feedback thread- http://www.stevemeadedesigns.com/board/topic/70871-dan208-feedback-thread/page__p__981961__hl__dan208__fromsearch__1entry981961
