Hey guys, im new to the forums and subs in general. In my car i currently have a 12" Pioneer TS-W1208D2 1400w sub. I found a cheap Sony Xplod 1000w mono amp for like $20 with 380 rms to power it. I'm looking to get a new box, new amp and another 12"Pioneer TS-W1208D2. The subs are 400w rms so it would be 800rms in total. Would i be better off getting a nice brand 2 channel 2000w amp or is 2 channels even needed? The sub is two 2 ohm voice coils or 4ohms (which in itself confuses me). I was just looking for some suggestions on amps, boxes ( ported or not) and if i will need additional things such as another battery or something.
I currently have my sub connected 4 ohms from the amp.
thanks for the help,
Brian
Edited by B-rab
is the sub a dual 4 or 2
06 chrysler 300C Hemi
one mmatts dreadnaut 15 powered by a planet audio vx 2200d
fosgate p200 running planet audio 8" midbass drivers and super compression tweeters
stock battery and a stinger spv44
Irragi 300 amp alternator
big 3 1/0
http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
Pretty sure its dual 2.
And just a fix its the Pioneer TS-W1208D2 not the D4
Edited by B-rab
well you can wire two and get a final two ohm load just need a mono amp thats two ohm stable thats 800 rms
big 3 1/0
do a little research what kind of budget do you have for buying an amp Im happy with my planet audio amp they also have a good warrenty if bought through a dealer but there are alot of good companies out there just do a little shoppin
big 3 1/0
u should shop around a bit. just dont go with sony. u could get a kicker zx750.1. thats around 800rms at 2ohms cuz kicker underrates their products. you can also get an extended warranty if install it with a kicker amp kit
NEW ORLEANS SLAP
Alpine CDE-103BT
2 12'' JL Audio W3v3-4
Hifonics HIF1500.1
that amp seems affordable and pretty good based on the reviews i read. What gauge wire would you suggest for this amp? I currently have 8-gauge wiring in my car, would 4 be better or not really make a difference? I'm trying to stay under $300 with this new setup. Found that amp for $200, Another sub will run me about 80 leaving not to much to spare. Also, Ported box? Any suggestions on Cubic feet and port size? Like i said im new to this but i can make the box.
thanks for all the help so far,
Brian
you want to go with 4 gauge when your running this kind of amp. 1.25-2.05 cubic feet for a ported box. im not to sure about the port size because im not that familiar with pioneer
NEW ORLEANS SLAP
Alpine CDE-103BT
Hifonics HIF1500.1
Could also get an AQ1200D, rated at 870 RMS @ 2 ohms. Would just have to be easy on the gains. But there are tons of companies around that will put out around 800 RMS @ 2 ohms, just have to shop around and find a solid one in your price range.
About what size wire, 4 AWG will easily work for this application. You could use 0 AWG if you wanted to... but you would have to shave the wire down a bit so it will fit into the amp.
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
  • Who's Online   1 Member, 0 Anonymous, 568 Guests (See full list)
