AQ recone options
i need to recone my audioque hd3 12 (not hdc3). my current setup is a 2.2 cubic foot slot ported box tuned to 38 hz and a amplifier that makes 1500 watts rms at 2 ohms and a dual 4 ohm copper hd3.
option 1. stock AQ recone, dual 4 ohm copper voice coil with 8 soft spiders.
option 2. fix my speaker.com team PSI recone. they recommend a dual 1 ohm flatwound aluminum voice coil with 3 stiff spiders.
option 3. AQ aluminum coil recone, dual 1 ohm AQ aluminum coil with 8 spiders. they can add extra spiders if requested.
which is better for my setup? the only reason i need a recone is my subsonic filter got turned off by accident and i bottomed out my sub hard enough to tweak the cone.
  • Who's Online   1 Member, 0 Anonymous, 1615 Guests (See full list)
