BeachJoshua Posted February 27, 2010 Report Share Posted February 27, 2010 How do I know what to play when I enter an SPL competition? Quote | S-10 | 4.5^3 ft | 33Hz | SAE-1000D @ 1 Ohm | 2 SA-12s | SPL: 143.7 Sealed | 153.4 Port Wars Link to comment Share on other sites More sharing options...
raytard Posted February 27, 2010 Report Share Posted February 27, 2010 How do I know what to play when I enter an SPL competition? they'll usually tell you, so uk if you can only play music or if sine sweeps/tones are fine if you're stuck with music play something consistant, like amilli by lil wayne or "boomin and bunkin" by oj da juice man for one run and then go higher or lower freq for the next runs to see whats loudest. if you can play sweeps or tones, do a sweep first and see about where youre peaking, and then do tones around there next, starting low and playing for a few secs and working up higher. Quote Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now) Team DC Link to comment Share on other sites More sharing options...
BeachJoshua Posted February 27, 2010 Author Report Share Posted February 27, 2010 they'll usually tell you, so uk if you can only play music or if sine sweeps/tones are fine if you're stuck with music play something consistant, like amilli by lil wayne or "boomin and bunkin" by oj da juice man for one run and then go higher or lower freq for the next runs to see whats loudest. if you can play sweeps or tones, do a sweep first and see about where youre peaking, and then do tones around there next, starting low and playing for a few secs and working up higher. Thanks ray, but where can I find this stuff? I can get the music? but should I make a disc of tones, and a disc with a sweep?? and how long of a sweep? starting where? ending where? the wheres are Hz wise... Quote | S-10 | 4.5^3 ft | 33Hz | SAE-1000D @ 1 Ohm | 2 SA-12s | SPL: 143.7 Sealed | 153.4 Port Wars Link to comment Share on other sites More sharing options...
BeachJoshua Posted February 27, 2010 Author Report Share Posted February 27, 2010 CD\ Audio: Any CD of audible format is acceptable. So I'm guessin I play what ever the heck I want. Quote | S-10 | 4.5^3 ft | 33Hz | SAE-1000D @ 1 Ohm | 2 SA-12s | SPL: 143.7 Sealed | 153.4 Port Wars Link to comment Share on other sites More sharing options...
Decaf Posted February 27, 2010 Report Share Posted February 27, 2010 see if they will let u play a sweep in qualifying then u at least have a general idea where ur peak is then find a song at that peak and jam away Quote Link to comment Share on other sites More sharing options...
