i have 3 pioneer 12s 400rms/1400peak each d2 ohm wired @ 1.33 ohm load.
I need help choosing between a Kole Audio Kx1-4000d or Kole Audio Qx1-3000d
Amp Specs Below:
Kole Audio QX1-3000D MONO D 3000W Amplifier
•RMS Power Rating:
•4 ohms: 1100 watts x 1 chan
•2 ohms: 1800 watts x 1 chan
•1 ohm: 2300 watts x 1 chan
•Max power output: 3000 watts x 1 chan.
•Fully regulated PWM power supply
•Wired remote bass level control included
•LED power indicators
•Tuned Bass EQ (0-18 dB bass boost)
•1 Ohm stable stereo
•Single-channel monoblock operation
•Preamp RCA outputs
•Hi-speed digital circuitry
•Four way protection circuit
•Heavy duty aluminum alloy heatsink for heat dissipation
•Gold-plated RCA level inputs
•Gold-plated screw terminals
•Variable low-pass filter (50-150 Hz, 24 dB/octave)
•Subsonic Filter (15-40 Hz)
•Frequency response: 15-150 Hz
•Dimensions(LxWxH): 16.8” x 11.25” x 2.25”
or
Kole Audio KX1-4000D MONO D 4000W Amplifier
•RMS Power Rating:
•4 Ohms: 1200 Watts x 1 Channel
•2 Ohms: 1700 Watts x 1 Channel
•1 Ohms: 2200 Watts x 1 Channel
•Max power output: 4000 watts x 1 channel
•Fully regulated PWM MOSFET power supply
•LED power and protection indicators
•Tuned Bass EQ (0-18 dB bass boost at 45 Hz)
•High speed digital circuitry
•Bridging synchronization capable
•Preamp RCA outputs
•4-way Protection circuitry
•System distress indicator
•1 ohm Stable
•Nickel-plated screw terminals
•Variable low-pass filter (50-150 Hz)
•Subsonic Filter (60-200 Hz)
•Dimensions: 14.8"L x 11.7"W x 2.2"H
What's your budget? You may be able to find a better amp for around the same price.
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
If you could raise that up to about $300 - $320, you can find an Audiopipe AP3000D. Which I would pick over those 2 amplifiers.
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
i was about to say the same thing
I know a lil about everything so dont call me Mr. Know it All.
  • Who's Online   0 Members, 0 Anonymous, 373 Guests (See full list)
