wires coming from the battery
i have a 2001 hoe im trying to do the big 3 and i wanted to know if this is right. i run 1 wire from alt to battery then two grounds. but the thing that gets me is on the stock wires there are two wires one running from the alt and another from under the box with the fuses. so what is the right way for me.
pioneer avh-p4200dvd (soon)
Highs amp Zx350.4, zx200.2
4 Kicker Cvx 15 D4
Sub amps (4) Zx1000.1 (need one more)
doors (6)kicker ks 650
Still under construction
Battery positive to Alt positive with a fuse on the wire.
Battery negative to chassis ground(Frame).
Engine block(or Alt. Bracket bolt) to ground.
Dont worry bout those wires. All you are doing is ADDING wires not replacing them! Correcst me if im wrong guys. Also use your search button, they have a nice thread just for the Big "3"
Current Setup:
Sony CDX-7401UI
2- 12" Alpine TypeR DVC2ohm Subs
Custom ported box
4-American Bass 6.5in SQ-6B Mids
4-Pioneer TS-T15 Tweeters
2-Crunch P1500.1 Mono Amps
2-runs 1/0 GA KnuKonceptz
KnuKonceptz RCA's
1-Stinger SPV44 Battery
Coming soon:
250 Amp Alt
Custom Door Panels
Second Skin Sound Deadner
All in my 1986 Monte Carlo SS!!!
Your correct. You leave all stock wiring in place, as your only adding the new wires to it. Also here's the thread for the Big 3 Upgrade.
  • Who's Online   0 Members, 0 Anonymous, 930 Guests (See full list)
