so i have 2 kicker L5 duel 2 ohm squares @ 600 watts a piece and i have 2 alpine mrp-m500s, the alpines are 500 watts a piece @ 2 ohm and i was wondering if i should wire them at 1 ohm, 2 ohm or 8 ohm. the amps are stable @ 2 ohm but i would like to wire them @ 1 ohm??? would that hurt the amps???
What kinda electrical upgrades do you have... Alt. Batts?
HU...Pioneer 5900IB
Wireing...Stinger
Amps...(1) Modded Stetsom 2K6..
Batts...(1) Stinger 2150
SPL Subs...(2) DD 9515 Hybrids
Daily Subs..(1) Mmats P3.0 15
N.S.P.L.
2012 NC State Record Trunk 1801-3600
2012 World Record Trunk 1801-3600
2011 NC State Record No Wall 0-24"
2011 NC State Record No Wall 0-24" Hardcore
2011 World Record No Wall 0-24"
2011 World Record No Wall 0-24" Hardcore
2010 World Record No Wall 0-2500w
2010 NC State Record No Wall 0-2500w
2009 NC State Record No Wall 0-24"
2009 NC State Record No Wall Hardcore 0-24"
those amps are not one ohm stable. u really need a mono block that can run 1 ohm
Edited by t-money
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
its a all stock 1999 Dodge Durango
Then i would not recommend running them down to 1ohm... Upgrade you electrical then you may be able to run them down that far.. I had my stetsom 1k4 1ohm version running 0.5 daily for about 6 months but i had 2 batts and a upgraded alt..
HU...Pioneer 5900IB
Wireing...Stinger
N.S.P.L.
The best you can do is run each sub at 4 ohm off each amp.... Or one amp, 2 subs @ 2 ohms..... Alpine's amps are especially sensitive when it comes to the protect mode. No running those at 1 ohm, they will shut off.
so i should run the woofers at 2 0hms each amp???
