need box diamentions for subs to build on my own
whats up guys im new here but not new to car stereo i am planning on building my first box i need the dimensions and what the port should be. i just want a regular slot ported rectangle box
car trunk dimensions
width- 41"
height-14 1/2"
depth 15"
i am not opposed to using filler to make the box seem bigger
speakers
(2) RE SX 12" d4
# Nominal Impedance -Znom: Dual 4 ohm
# Thermal Power Handling -Pe: 1000 W
# Force Factor -Bl: 21
# Electrical Q Value -Qes: .32
# Mechanical Q Value -Qms: 4.4
# Total Speaker Q Value -Qts: .30
# Free Air Resonance -Fs: 30.6 Hz
# Equivalent Compliance -Vas: 47.6 liters
# One-Way, Linear Excursion -Xmax: 22 mm
# Efficiency - SPL 1W/1m: 88.1 dB SPL
# Effective Piston Area -Sd: 480 cm^2
# DC Resistance -Re: 1.9 ohm
# Mounting Depth - 6.5”
# Mounting Hole Diameter - 11”
# Overall Diameter - 12.5”
# Bolt Hole Circle - 11.75”
# Motor Width - 6.5”
# Motor Depth - 3.25”
# Basket Depth - 3.25”
# Displacement - .16 cu. ft.
i listen to mostly rap music
thanks for the help
  • Who's Online   0 Members, 0 Anonymous, 1303 Guests (See full list)
