gogojjt Posted March 25, 2010 Report Share Posted March 25, 2010 just wanted to add a few more cents on troubleshooting....if you dont think its your headunit......try replacing your rca's and see if the noise stops....does this noise happen when the engine is off? that could eliminate the alternator whine...could place a ground loop isolator in line with rca's and try that........or a noise filter. volt match gain on amp with rca output of headunit...other than a better ground i cant think of any options...sometimes using different companies will cause noise.....like sony headunit with pioneer amp...if none of that works i would try a fully functioning head unit as i said above...goodluck Quote Link to comment Share on other sites More sharing options...
