GORILLAslap Posted March 27, 2010 Report Share Posted March 27, 2010 (edited) my buddy has a JL audio blk e11 500x1 amp, and the old school kicker comp vrs dual 4 ohm ( black) 10s, an i just need to know whats the best ohm to run them at.... itold him 8ohms HIS JL AMP IS OLD SCHOOL NAVY BLUE NOT WHITE Edited March 27, 2010 by GORILLAslap Quote starting fresh, chrysler 300.. no subs amp nothin I NEED HELP looking to purchase saz-1500d and 15" 1000rms subREFS- feedback/refs.. click! Link to comment Share on other sites More sharing options...
GORILLAslap Posted March 27, 2010 Author Report Share Posted March 27, 2010 bump PLEASE Quote starting fresh, chrysler 300.. no subs amp nothin I NEED HELP looking to purchase saz-1500d and 15" 1000rms subREFS- feedback/refs.. click! Link to comment Share on other sites More sharing options...
ISO Posted March 27, 2010 Report Share Posted March 27, 2010 (edited) Ya about 8 ohm would be best. As long as they are the Comp VR witch is actually the Competition D series I would recommend 125 to 150 watts RMS per woofer and a sealed airspace of 1cf to 1.25cf. These only came in a single voice coil. Edited March 27, 2010 by ISO Quote Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character. Link to comment Share on other sites More sharing options...
ISO Posted March 27, 2010 Report Share Posted March 27, 2010 (edited) If they are dual voice coil then each woofer can handle 300 to 350 watts a piece and these woofers work in sealed and ported boxes. Wire that amp down to 1 ohm if it can handle it. Edited March 27, 2010 by ISO Quote Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character. Link to comment Share on other sites More sharing options...
GORILLAslap Posted March 27, 2010 Author Report Share Posted March 27, 2010 Ya about 8 ohm would be best. As long as they are the Comp VR witch is actually the Competition D series I would recommend 125 to 150 watts RMS per woofer and a sealed airspace of 1cf to 1.25cf. These only came in a single voice coil. there dual 4ohm FOR sure but they are kicker comp vr , an there black Quote starting fresh, chrysler 300.. no subs amp nothin I NEED HELP looking to purchase saz-1500d and 15" 1000rms subREFS- feedback/refs.. click! Link to comment Share on other sites More sharing options...
ISO Posted March 27, 2010 Report Share Posted March 27, 2010 there dual 4ohm FOR sure but they are kicker comp vr , an there black I used to run them before I moved up to the L7's. Answer above. Quote Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character. Link to comment Share on other sites More sharing options...
kmalinich Posted March 27, 2010 Report Share Posted March 27, 2010 If the subs are indeed dual 4, you can series the voice coils to 8 ohm, and then parallel the speaker leads to 4 ohms. Unless the amp is 1 ohm stable, then parallel everything ... which would give you a 1 ohm load. I can't find the specs for that amp online, though. I'd stick with 4 ohms until you know for sure. Quote Link to comment Share on other sites More sharing options...
GORILLAslap Posted March 27, 2010 Author Report Share Posted March 27, 2010 I used to run them before I moved up to the L7's. Answer above. how do i know what ohm the amp is at? i understand how to bring the subs to 8ohms ( pos-neg neg-neg) Quote starting fresh, chrysler 300.. no subs amp nothin I NEED HELP looking to purchase saz-1500d and 15" 1000rms subREFS- feedback/refs.. click! Link to comment Share on other sites More sharing options...
GORILLAslap Posted March 27, 2010 Author Report Share Posted March 27, 2010 ??? Quote starting fresh, chrysler 300.. no subs amp nothin I NEED HELP looking to purchase saz-1500d and 15" 1000rms subREFS- feedback/refs.. click! Link to comment Share on other sites More sharing options...
ISO Posted March 27, 2010 Report Share Posted March 27, 2010 I gave you the specs on the 2 different type of Comp VR but I don't see anything in JL's discontinued amp lines. http://mobile.jlaudio.com/products_amps_pages.php?page_id=208 Quote Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character. Link to comment Share on other sites More sharing options...
