TeejayBee Posted March 29, 2010 Report Posted March 29, 2010 I have two amps , one puts out its 1000-1300 rms power but the other dosnt seem to be Im running one sub per amp any ideas on why this is happening. the "Bad" amp turns on im just not sure what the problem is.
Mattintc Posted March 29, 2010 Report Posted March 29, 2010 I have two amps , one puts out its 1000-1300 rms power but the other dosnt seem to be Im running one sub per amp any ideas on why this is happening. the "Bad" amp turns on im just not sure what the problem is. The " bad " amp may just be wired incorrectly on the speaker terminal part of it but it also may be a fuse or there is not equal power going to each amp in house subwoofer system FTW but nothing special 1 12 inch lanzar vibe 1600 watts subwoofer box tuned to 36hz no amplifier ATM 1 350 watt antec power supply 1 300 watt antec power supply 2 other brand 300 watt power supply four in total all four gauge to the soon to be amplifier Bus bars 1 simple bass boost Videos at www.youtube.com/walkingfreak
TeejayBee Posted March 29, 2010 Author Report Posted March 29, 2010 they are wired correctly ill re check today and im going to also check the power too
Toady Posted March 29, 2010 Report Posted March 29, 2010 they are wired correctly ill re check today and im going to also check the power too it could be several different things. make sure that you have the correct ohm loads, proper wiring and fusing, good rca signals, good grounds, sometimes these factors can do this to an amp, i've experienced it with an install in a different car. Are you running a distribution block?
jmitch Posted March 29, 2010 Report Posted March 29, 2010 yo u using a y to split the signals from the rca's? I know a lil about everything so dont call me Mr. Know it All.
TeejayBee Posted March 30, 2010 Author Report Posted March 30, 2010 I just retuned my amps today and it fixed it and i need to get a better ground and everything is perfict T3- subs all the way to be honest
