thats what fosgate says per sub. they dont move much air at all. ive got a kicker 800.4 i plan on putting to the pair. for the first 5 1/2" of the box actualy. the sub goes down in diameter at 4 1/2" if i go subs up the trunk will go ape shit. i dont want the assend to rattle like a can. it is gonna move abit even with the subs and port into the cabin.
And far as the best connection ever.......
get a huge fucking battery, cut the top off, drop an alt in there and then pour all that into your big amplifier. or just smelt them all together.
for the box size total?
i dont think i could even get away with that in the space ive got. im just gonna stick with 2.75 apiece. there will be maybe 350w per sub.
again its up to you... in my experience big sale pushing companies keep the box small to save warranty returns from customers not knowing limits. a bunch of us build boxes way out of the realm of specs and yield much better results. again its up to you. you should build test boxes to prove it to yourself.
try building one to spec with the 2.75 and 4" port
then try a 4.5 with slot port at ~14^2 per tuned to that 35hz.
