t1000-4
SYNDICATE
So you'll be running the tweets on a separate amp?
You could do 4 svc woofers per channel. Depending on the ohms the speakers are, you could wire 4 8 ohm woofers to 2 ohms or 4 4 ohm woofers to 4 ohm.
Just make sure you have a active crossover to set the frequencies to the appropriate amps.
The amps does:
150 Watts RMS x 4 @ 4-Ohms
250 Watts RMS x 4 @ 2-Ohms
I am sure it births a little higher... as RF always does.
  • Who's Online   0 Members, 0 Anonymous, 643 Guests (See full list)
