u4ria Posted April 8, 2010 Report Posted April 8, 2010 hey i would really like some help in buliding a spec box for these subs 2 x 15" Starsound ssw 381 spec on subs :Starsound Carbon Series 15" 380mm 2000w peak power 1000w RMS power 2.5" Aluminium Bobbin single voice coil Treated cellulose cone Rubber surround Carbon fibre Dust cap Sensitivity 89db/spl Independence 4ohm 1 x targa 6000watt monoblock 1 Ohm RMS Output @ 0.05% THD: 2000WRMS x 1 Maximum Output Power:6000 Watts Bass Level remote Control (16.4ft):YES Low Pass Filter (Variable):N/A High Pass Filter (Variable): 80Hz - 1.2kHzSubsonic Filter:20Hz - 50Hz Frequency Response (-1dB):20Hz - 250Hz Signal To Noise Ratio ('A' WTD): >100dB Input Sensetivity: 200mV - 6V Input Impedance:22k Ohm Operation Voltage (negative Ground): DC 12V 1 x 3300watt 4 channel playing 4 sets of splits i got these items as a gift would ne1 plz advice on how to bulid a very good spec box so i can get a good DB nr while playing my sound everyday im using it in a opel keddet cub 4 door height till back board 52cm length 98cm widht from back seats 80cm thanx u4ria
