I need it todo either 2-3k rms at 1ohm or something like audiopipes amps where you can run both subs at 2 ohm . If you have one i can trade my two Kicker zx 1000,1 both are perfect i just want one amp .
  • Efficient Class D Amplifier Design
  • 2250 watts @ 1 ohm
  • 1750 watts @ 2 ohm
  • THD at 1 Watt, 4 Ohm - 0.30%
  • THD at Rated Power - 0.50%
  • Signal-to-Noise Ratio, below rated power output - 100dB
  • Frequency Response, at 1 Watt, 4 Ohm - 15Hz to 150Hz (+/-3dB)
  • Frequency Response, at Rated Power, 4 Ohm - 20Hz to 250Hz (+/-3dB)
  • Damping Factor at 20Hz, 4 Ohm - 400
  • Crossover: Low Pass - 50Hz-150Hz, 24dB/Octave
  • Crossover: Subsonic (High Pass) - 15Hz-40Hz, 24dB/Octave
  • Bass Boost - 0 + 18dB
  • Phase Control (Switchable) - 0 to 180*
  • Input Sensitivity - 100mV to 2V
  • (2V to 8V COMPATIBLE)
  • Input Impedance - 10K-Ohm
  • Line Output Impedance - 100 Ohm
  • Peak Current consumption, at rated power into 1 Ohm - 175 Amperes
  • Dimensions (W x H x L) - 10 5/8" x 2 7/16" x 18 3/4"
