DC Sound Lab
12" Level 3 in Glove box Build
Hey Guys, new to the forum so i figured i would post up my current build. I am a friend of Clay's (The A Team)and he is my supplier of all things DC :orly3:
I hope this might be of interest to you guys, shows you the versatility of DC products and it is something a little different.
I am just going to copy my other thread, here is the original if anyone is curious. http://www.fiberglassforums.com/showthread.php?t=12039
______
This will be my build log as i attempt to put a 12" DC Audio Level 3 into my dash in the stock glove box location. It should be interesting...
The vehicle..
I used to run a DC audio Level 5 and a stetsom 2k in my truck. Unfortunately it required a much larger box then i would like in my truck and it was not practical as i use my truck for 4wheeling quite often. So i decided to downsize and keep as much usable cab space as possible.
A comparison of the Level 3 (on the left) and the Level 5 (on the right)
the box, as you can see it took up the entire backseat behind the driver
Naturally the next best place for a sub in my truck is the glove box so that's what i set out to do..
after 2 layers of glass mat
That,s basically where i am at right now. The original Plan was to do 1 cf sealed if i could fit that however as it stands right now Im at around .85 cubes for just the back part of the box. After adding the front i will possibly be over 1.5 cubes. if that is the case i will be porting this using a 4" aeroport.
thanks for looking, stay tuned..:cool:
Edited by mikey060
here is what i have got done today so far..
first problem which i had anticipated
i decided it would be easier to relocate my tweeters to the a pillar and i also save myself from losing a lot of volume in that corner. the imagining from those speakers is just how i like it but i cant imagine the a pillar being too different.
i will mount the tweeter on the little black triangle, the mirror mount, at a later date.
this pic shows how much room you still have.
i am 6'3" and can comfortably sit without bending my legs in. obviously you would not want to take this truck on a road trip with a passenger
Got a little more done today, would have done more but i ran out of resin :rolleyes:
Figured a way to harness the box to the truck
removed the stock grommet in the firewall
marked and drilled a hole then inserted a 1/2" bolt with washer
too long
much better
view from outside the passenger window. from a thieves point of view :P
The one bolt through the firewall holds the box in nice and secure however it still needs some vertical support. Also needs the vertical support to help level it out so the glove box looks proper. I will make some sort of bracket tomorrow to help support it. Will be in the red circled part of the picture below.
apparently the last bit of resin i used was a little old. it was only about a quarter of a quart that i used. its a nice money color haha
never seen this before should be interesting
04 dodge dakota ext cab 4x4
excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
ya im for sure sticking around to see this.. where are you mounting your amp?
2 Fi BTL N2 18s Fully LoadedSundown Audio NS-1Kenwood 845 HU Clarion EQ4 Juicebox 3100sKnu Wire"Big 3"Mechman 270a156.3dBTeam GG.
  • Who's Online   0 Members, 0 Anonymous, 1347 Guests (See full list)
