Ok so the other night I got was installing a radio in my 03 Acura rsx, I got all the wires hooked up correctly and everything but the headunit did not power on. I thought this was odd so I hooked up the headunit to a 12v battery to see if it worked and it did. The car also had a aftermarket headunit installed before. I bought a new Acura harness because I thought it could be faulty, switched it out and nothing. I then hooked up the red power on the alpine 9886 harness with the car's red wire and I also added the yellow wire together with the reds and it powered on. Now everything works but doesn't hold my settings and such. Any ideas on what I could do? Basically the yellow wire on the car harness is dead :(
Alpine 9886
Polk Audio 6.5 Component db series
Elemental Designs nine.4
JL Audio 1000/1
DC Lvl 4 15" - 3.95 cu ft/tuned to 32 hz
Clarion EQS746
Stinger Voltage Meter
Optima Yellow Top (Front)
XS Power 1200 (Rear)
All KnuKonceptz Wiring
IIRC the yellow is your constant so you could run a wire to the + on your battery and connect red to red.
It doesn't save any of your settings because your constant isn't always getting power.
TEAM FLEX ISSUES
Car: 1985 Oldsmobile Delta 88 Royal
24" Rims
HU: 7" Carputer, Planet Audio EQ, iPhone.
Coax: T3 Audio 4" speakers
Subs: 2x 18" T3 Audio TSNS (walled)
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MB Quarts 6.5" comp set
MAYBE ADDED
2nd DC 9k
You could run the yellow wire directly to your battery(make sure you put a inline fuse inbetween) and run the red wire to anywhere that has power when the key is in the ignition.I had an 02 rsx type-s but never had this problem.
What gauge wire and what size fuse should I use??
Alpine 9886
JL Audio 1000/1
Clarion EQS746
Would 16 gauge wire be ok??
Alpine 9886
JL Audio 1000/1
Clarion EQS746
You could use whatever size you want.
TEAM FLEX ISSUES
24" Rims
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MAYBE ADDED
2nd DC 9k
Thanks again for the help guys. I'll let you guys know how it turns out when I do it.
Alpine 9886
JL Audio 1000/1
Clarion EQS746
  • Who's Online   1 Member, 0 Anonymous, 2570 Guests (See full list)
