Kinetic battery problem
shipping is prob like 50 bucks which sucks.. this has free shipping atleast
http://www.audiosavings.com/products/Kinetik-Battery/KINETIK-KHC2400-POWER-CELL-CAR-AUDIO-BATTERY-HC2400/KHC2400.aspx
better yet they have the red racing version, no difference only lighter for like $270 shipped
d(-__-)b
A mechanic did the same to the HC1800 I currently use, I was able to get the bolt out though. So I just tapped it with a fine thread and it's been good ever since. See if you can't get pliers to hold the cylinder it goes in then hit it with open end a few times. If you can get the bolt out.. You can salvage your battery maybe
1993 Chevrolet SWB Pickup
Viper 791XV
Primer Stage
5/8 Static Drop
Kinetik HC1800
Big 3 Knu Flex 0
Team Tex Flex
So you are currently using a battery that the pc where you bolt down your wires, spins? With no problems? Kinetik said that it will probably still charge but will not have a good connection.
I am mostly worried that something might go wrong with it for whatever reason. I dont need a battery assploding in my truck
d(-__-)b
Mine doesn't spin in COMPLETE circles, it has a little play in it.. All of them will if you over tighten them or cross thread. The insert for it was cross threaded and I held with pliers on the cylinder portion and got the bolt out, tapped and then reinserted a fine threaded bolt in it's place with lock washers on top/bottom to ensure it doesn't really spin again when tightening it.
Mine was never lose to the point where the connection was bad. I find myself disconnecting both terminals over time to clean the damn things off anyways because they get dirty and lose a bit of contact...
Viper 791XV
Primer Stage
5/8 Static Drop
Kinetik HC1800
Big 3 Knu Flex 0
Team Tex Flex
Yeah mine spins, now once I saw that it was spinning I stopped trying. I wanna cry.
Anyone wanna buy some kids, I have 3. Surely one semi-used child is worth $300.
d(-__-)b
  • Who's Online   0 Members, 0 Anonymous, 589 Guests (See full list)
