white4d96 Posted April 27, 2010 Report Posted April 27, 2010 Both my back brake calipers are sticking up a storm so I am going to try and rebuild them. I found the kits for cheap at an O'Reilly's near me, but I have no clue how to do this (plan on picking up kits tomorrow.) What tools do I need and how do I do it? Quote Too many projects, too little time...
killallblue Posted April 27, 2010 Report Posted April 27, 2010 U need a caliper 3/8 drive wrench bit Quote
white4d96 Posted April 27, 2010 Author Report Posted April 27, 2010 One of those little $8 parts-store jobs do the trick? Just guessing, I unscrew the piston (after I disconnect the caliper and all that jazz), pop the seals off, clean everything, pop new seals in and screw the piston back in? Quote Too many projects, too little time...
killallblue Posted April 27, 2010 Report Posted April 27, 2010 Yup but when u hook every thing bake up make sure u bleed the breakes best way is to buy a 30 dallor break bleeder it's worth it Quote
white4d96 Posted April 27, 2010 Author Report Posted April 27, 2010 I can bleed the brakes pretty easy. I typically make a bleeder on the spot with a water bottle and some hose. Actually now may be a good time to change my brake fluid too. Quote Too many projects, too little time...
killallblue Posted April 27, 2010 Report Posted April 27, 2010 U can paint the caliper while it's out to Quote
white4d96 Posted April 27, 2010 Author Report Posted April 27, 2010 Meh, then I'd wanna do the fronts too and that's just too much work. Besides, can't really see them through the wheels (stock steelies FTL) Quote Too many projects, too little time...
killallblue Posted April 27, 2010 Report Posted April 27, 2010 O I thought u might be able to see them like on my stock blazer rims when I re did my breaks I painted all mine flat black Quote
white4d96 Posted April 27, 2010 Author Report Posted April 27, 2010 Some members of a GP forum said I should just buy remanufactured calipers with a warranty because they go out frequently. Anyone else had this issue with these cars? Quote Too many projects, too little time...
