I am running audiobahn 12 aw1206t 1100 rms 2200 max and i am looking for the best possible amp to push it. budget is about $275. i will possibly be running 2 of them so i will be buying 2 amps if that happens. but for now just the one. help much appreciated. the $275 is just for one amp so if 2 amps then budget is about $500 to $600.
Edited by xXx iKoN xXx
1999 Honda Civic DX Coupe
Head Unit: Panasonic CQ8100U (Temporary)
Front: 6.5" Kenwood KFC-1662S
Rear: 6"x9" Kenwood KFC-6989ie
Sub: Undecided
Amp: Undecided
Big 3 Upgrade (4 gauge)
Marine Battery routed to the trunk
Stock Alternator for now
http://www.audiobahn.com/Audiobahn06/images/products/woofers/flameqspecs07.jpg
specs for the sub are in the middle if that will help any.
Sub: Undecided
Amp: Undecided
bro!! wattz is selling t1000.1bd's and im pretty sure he can do 275 shippped. they got the knob and box and birthsheets like new. what ohm load are you trying to run em at? i think they do like 1100-1200rms at 2 ohm and the one i bought from him does 1639rms at 1 ohm.. best bang for the buck man
I want to run them down to 1 ohm if that possible but I would have to look up how to wire the sub for that. but i want to be able to get at least 2000 watts to the sub.
Sub: Undecided
Amp: Undecided
Why run 2 amps if you go two subs?
I have no doubt you will want two subs after you get used to one sub, so for now go two subs and get you a 1 ohm amp that can push them.
1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31
i want the most power to the subs. and i figure 2 2000 watt amps, 1 to each sub would be more bang than 1 2000 watt amp to 2 subs
Sub: Undecided
Amp: Undecided
Im not familiar with these subs too lazy (buzzed) to research,but can they handle 2000 rms each? if so, then look in to getting a 1 ohm stable amp that does 3000 rms plus.
but i mean i already one sub hooked up to a piece of crap boss 2500 watt amp and my rear view mirror falls off and it flexs my windshield. so i think i am only going with the one to save trunk space as well as give me more options in the future.
Sub: Undecided
Amp: Undecided
the subs max out at 2200 so then any advice on a 1 ohm stable 3000 watt amp???
Sub: Undecided
Amp: Undecided
1 ohm stable amp for 3000 rms you have lots of options, question is whats your budget?
  • Who's Online   1 Member, 0 Anonymous, 1675 Guests (See full list)
