i am assuming that you have Dual 2 ohm subs. IF SO THEN READ ON
wire both subs to 1 ohm each. then wire them together OR put the positives from each sub in their own positive channel and the negatives in their own negative channel. this will give the amp a nominal 0.5 ohm load
like this:
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=22#results
have a good day kind sir, i accept tips and bj's B)
thanks for the help everyone. and tip i can give liquor in the front poker in the rear. sry no bj's
Edited by Reaper
