hi all, im new on here, been following SM for a while now on youtube etc. love the work this guy does!
im from the UK by the way :D
so here is my latest build
Equipment consisting of
Source - Alpine 7998R w/ Alpine KCA420i iPod adapter
Amps/Speakers - 2x JBL 75.2 powering 2x sets Focal 165V30 6.5" components (the 2 JBL's will probably be changed for a DLS X-D40 4ch amp to help increase space due to extra batterys in the boot and to allow for a decent sized box for the RE XXX)
Amp/Sub - Orion D5000 powering 12" RE XXX v4
Power - standard 70amp alt, 3x Odyssey PC1700's, 0awg main feed and appropriate cabling to amps
Doors will be deadened with Dynamat Extreme, 2/3 rolls per side
so started off the other day by building the tweeter builds.
then today moved onto the door builds, not sure what layout i prefer, what are your thoughts opinions? Layout A or B?
spent the past few days getting the rca, power, remote cables etc run, head unit in, doors drilled and grommet'd, dynamatted, 2 layers on the outer, still to do the inner. boot is now deadeded 95%, only a small amount left to do, need the rear arches done but im going to need more dynamat.
also been working on the a pillars and the door builds. ill let the pics do the talking....
severe rot has set in and i can see daylight.... not good, notice the seat belt mech bolt..... :eek:
didnt get as far as building anything but i got my mids in the door, cables are soldered. look well :D
so thats the front end sorted out, just to worry about amp rack and false floor. on a side note, i ordered distro blocks from CAS on wednesday, order was processed on thursday and then they were posted on friday..... then they say that the delivery will take 3 to 4 days!!!!
pitty CAD didnt have what i needed :( would have had it an all!
small update, got my fused distro block and fuses
also got my arches welded up, sealed them, primed them with zinc primer then finished off with 2 coats of red primer
