BTL FTW Posted June 8, 2010 Report Posted June 8, 2010 I'm building a sub box for my girlfriends Smart for two. I'm planning on slot porting with a single 8 inch sub. the sub box is a rectangle 18 inch long 14 inches hight and 9 inches with external. I was wondering if putting the sub on the same face as the port which is facing the end of the rectangle firing towards the rear or sideis a good idea or it using a steve meade style box with sub up port back is better. Alpine F1 Status DD CS6.5 x2 Front Stage DD 9512H DD M4a @ 2 ohm DD S2b @ 8 ohm per channel I run high ohn loads for MASSIVE headroom and cleaner SQ 270amp alt D2400 up front D3100 x2 batter in back
thebiggmann12 Posted June 8, 2010 Report Posted June 8, 2010 its really all about testing which one will be loudest. i would start with sub back port back, then if that doesnt sound good, cover that hole with a peice of mdf, and then cut a hole in the top and mount the sub on the top.
