Boon Posted June 14, 2010 Report Share Posted June 14, 2010 thats ur problem u need to upgrade ur wire to atleast 4 gauge cuz ur starving the amp of the power it needs to run nice Small wire will not make an amp run hot. Too low ohm load, too much gain and a clipped input - that'll make your amp toasty warm. Quote 10.x volts fo' life! Link to comment Share on other sites More sharing options...
s_carter Posted June 15, 2010 Report Share Posted June 15, 2010 actually low voltage is the most likely culprit. check what kind of voltage it is getting, and measure your vdrops at the terminals and at your ground points. my guess is you got a bad connection somewhere. Quote Custom Sounds NW takes your ideas and turns them into your reality. Custom enclosures, consultations, service and installation of mobile electronics and home theater equipment. References available! My FB Page Two fully loaded fi SSD18's + Soundstream Rubicon RUB1.2500D wired to .5 ohm for 3600 RMS = Bass for your face! Link to comment Share on other sites More sharing options...
