well for about 2 days now, my itunes is refusing to connect to the internet, as you can see my internet is working perfectly fine, keeps saying "Make sure you network connection is active, then try again" its not being blocked by my firewall so idk the fuck the problem is! helpppp!
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
Try going to ADVANCED in iTunes and if "Home Sharing" is enabled, disable it for now. Also, Open Internet Explorer, Click: TOOLS,INTERNET OPTIONS, CONNECTIONS, LAN SETTINGS and uncheck AUTOMATICALLY DETECT SETTINGS & USE PROXY SERVER... sometimes that hinders it... Also, if your using Windows 7, make sure your internet connection, (NIC CARD) did not get switched to PUBLIC NETWORK instead of either HOME NETWORK or WORK NETWORK...
  • Who's Online   0 Members, 0 Anonymous, 1593 Guests (See full list)
