matt6387 Posted June 16, 2010 Report Share Posted June 16, 2010 Either remove it or put it on the otherside. This will prevent you from having a dead batt. It could also prevent damage to your amp? Low volts kills amps this would stop that. If you connect it right you could even set it up so that its only accessories on the turn off side that'd be sweet! Quote Link to comment Share on other sites More sharing options...
