eastcoaster91 Posted June 14, 2010 Report Posted June 14, 2010 ok the only thing i can think of is take out the back glass and somehow mould a box to where its sealed in the opening but idk if it can be done.
Alexdb7 Posted June 14, 2010 Report Posted June 14, 2010 your better off cutting a hole between the bed and cab and building a blowthrough, then sealing up the hole. build your box in the bed, but you will need the whole bed sealed up with a hard top cover Custom Car Audio (815) 916 - 9194 www.midwestsplcustoms.com 2000 Tahoe | 22" GREED Celebrities Alpine CDA-117 Dual 0/1 Runs (3) 925 CA Group 31 In Back (4) 18" FI Audio Q's (W/ Extra Spider) (4) Hifonics BXi 2010D Hifonics ZXi 4410 4 RF P1653 6 1/2's Big 3 All Kicker/Knu Wiring
eastcoaster91 Posted June 14, 2010 Author Report Posted June 14, 2010 your better off cutting a hole between the bed and cab and building a blowthrough, then sealing up the hole. build your box in the bed, but you will need the whole bed sealed up with a hard top cover the only thing i might see going wrong there is the bed twist from going out in the trails since its 4x4
Guest Posted June 14, 2010 Report Posted June 14, 2010 the only thing i might see going wrong there is the bed twist from going out in the trails since its 4x4 offroading + stereos = not a good mix
eastcoaster91 Posted June 14, 2010 Author Report Posted June 14, 2010 offroading + stereos = not a good mix not hardcore offroading but im gonna look into blowtrough tho thats the only way i could get the thump that i was in a small area
