now534 Posted June 20, 2010 Report Posted June 20, 2010 Ok so i bought this Focus ZX3 and picked up some Kenwood KFC-W3009 Subs. They are the 12" 4ohm model and im needing a box built or at least some dimesions for it. I can handle designing the box but the whole port tuning gets me confused. What i am looking for is a box built for 2 12's Ported and 32-37hz. I want the box to be 3 cu. ft. after sub displacement and port displacement. My Maximum Outer Dimensions of the trunk space i want to use are: Width:39.5" Height:20" Depth:20" I would like to run a Slotted Port i know its probably not the best style but i really do not want to buy anything else for this setup besides the wood. The whole box i will be using 3/4" MDF and for the front baffle i would like to use 1"MDF but can use 3/4 if i have to. The amp i am using is my Profile HA1000. I've used it on a lot of setups and plan to use it on this one for a temporary setup. I will plan on upgrading the amp in the future though. http://www.profileusa.com/products_amps_habaha.cfm I have no idea if i can run the Amp bridged and split the 4ohm from the amp between the 2 subs but if i can thats what i would prefer to do. If you can help me out with this that would be greatly appreciated.
