monster9391 Posted June 23, 2010 Report Posted June 23, 2010 I have 2 hifonixs brutus bxi2006d's and i only want one bass know how do i do this i dont need 2 bass knobs like i am currently running. Does maxxsonics make a dual input bass knob? Input is appreciated Pioneer deh 2100b (2)Hifonics Brutus BXI2006D Crossfire 200 watt 2 channel soon to be 4 DC level 3 15's (2)gel batts Big 3 200 Amp Alt
Cashdollar2009 Posted June 23, 2010 Report Posted June 23, 2010 http://cgi.ebay.com/Maxxsonics-MX-3-Bass-Sub-Integration-Controller-OEM-/300435513323?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item45f35a1feb#ht_1792wt_976 I used to run one of these with my two old brutus 1610d's. I believe it 1. helped, and 2. made it more convenient wiht only on remote to worry about. On 6/30/2011 at 1:11 AM, 'Ray' said: Acoustical energy is free. Electrical energy is not.
Freshman6969 Posted June 23, 2010 Report Posted June 23, 2010 theres a bass knob which i have, which hooks into the RCA, pretty sure thats the easiest way to do it without getting an EQ or anything, gimmie a sec ill get a link edit: heres the link, buy it here its cheaper then off the actual site http://cgi.ebay.com/PAC-LC-1-LC1-Stereo-Remote-Level-Controller-Bass-Knob-/360270426678?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item53e1ca7236 Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k! Why would you EVER WANT flex?huh?...flex is what can make the lows lower and more air being pushed correct? My FeedbackJeep-BuildlogPT LOSER buildlog
monster9391 Posted June 23, 2010 Author Report Posted June 23, 2010 http://cgi.ebay.com/Maxxsonics-MX-3-Bass-Sub-Integration-Controller-OEM-/300435513323?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item45f35a1feb#ht_1792wt_976 I used to run one of these with my two old brutus 1610d's. I believe it 1. helped, and 2. made it more convenient wiht only on remote to worry about. thanks brah looks like a winner Pioneer deh 2100b (2)Hifonics Brutus BXI2006D Crossfire 200 watt 2 channel soon to be 4 DC level 3 15's (2)gel batts Big 3 200 Amp Alt
Guest Posted June 23, 2010 Report Posted June 23, 2010 theres a difference between a "bass" knob (which boosts a frequency, usually 45hz, and used incorrectly can cause undesired side effects) and an inline RCA knob. the RCA knob is just a variable resistor which means itll change the voltage from what the preouts give. meaning if you have 4v coming from the headunit, and the knob is all the way up, your amp will see 4v. if the knob is half way (example), then the voltage can be 2v. thus making it quieter
