white4d96 Posted July 2, 2010 Report Posted July 2, 2010 When I ran my 1/0 through my car I didn't have a drill bit big enough. I used a hole saw my friend had, which IIRC was 1.5" (maybe 1" but I doubt I'm that lucky.) At the time I had just stuck a ton of tape over the metal to protect the wire, thinking I would find a grommet and order it quickly. WRONG! So I was wondering what you guys did for grommets with holes that aren't your standard '- gauge' holes. I have heard some people say to use liquid gasket but I would feel much safer with a real grommet. Too many projects, too little time...
Freshman6969 Posted July 2, 2010 Report Posted July 2, 2010 i personaly dont have any O.o, i have 4g and 8g cramed in 1 big hole i know its not the smartest thing but the wires are perfectly fine Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k! Why would you EVER WANT flex?huh?...flex is what can make the lows lower and more air being pushed correct? My FeedbackJeep-BuildlogPT LOSER buildlog
Loudcivic Posted July 2, 2010 Report Posted July 2, 2010 one of these may work http://badgerrubber.net/size1.htm and actually this place will have wut you need screw the other site lol http://www.midatlanticrubber.com/grommets.htm 2015 silverado crew cab nothing atm but soon...
