Mostar Posted July 6, 2010 Report Posted July 6, 2010 I want to run two sets of JBL P660c components in each front door. How would i wire each side to one channel? These comps are 2 0hm so i will have to wire them together to make 4 ohm... '05 GMC Envoy H/U: PIONEER AVH P4300DVD Subs: ( SA-12's Amps: (2) SAZ3500d's MECHMAN 270A Alt and 5 Batteries with lots of 1/0
Freshman6969 Posted July 6, 2010 Report Posted July 6, 2010 crossover, thats my guess, not to sure. bump for a definite answer Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k! Why would you EVER WANT flex?huh?...flex is what can make the lows lower and more air being pushed correct? My FeedbackJeep-BuildlogPT LOSER buildlog
rocknwoo Posted July 6, 2010 Report Posted July 6, 2010 4 ohm will give you less power, but if your amp has enough power at 4 ohm then go for it. You could run then parallel to get 1 ohm if your amp is stable at 1 ohm and you will do this at the input of the amp
Mostar Posted July 6, 2010 Author Report Posted July 6, 2010 My amp will do 100 watts rms per ch @ 4 Ohms. So temperarily i think that will work for me. Should it be wired to the amp like it is in my sketch up? '05 GMC Envoy H/U: PIONEER AVH P4300DVD Subs: ( SA-12's Amps: (2) SAZ3500d's MECHMAN 270A Alt and 5 Batteries with lots of 1/0
Mostar Posted July 6, 2010 Author Report Posted July 6, 2010 '05 GMC Envoy H/U: PIONEER AVH P4300DVD Subs: ( SA-12's Amps: (2) SAZ3500d's MECHMAN 270A Alt and 5 Batteries with lots of 1/0
Mostar Posted July 6, 2010 Author Report Posted July 6, 2010 bump ^^ '05 GMC Envoy H/U: PIONEER AVH P4300DVD Subs: ( SA-12's Amps: (2) SAZ3500d's MECHMAN 270A Alt and 5 Batteries with lots of 1/0
