Why not help him fix his wiring instead of recommending a different amp?
Wire up your subs like that for a 4 ohm load total (2 ohms per channel). You'll be seeing a lot less power, but you will stop blowing fuses.
When i had them wired like that, my lights dimmed HELLA bad it was awful, the amp barely pushed the subs wired like that.
2000 White Saturn SL2
Kenwood KDC-248U Head Unit
1 Rockrod Fosgate HX2 punch DVC 12
1 Rockford Fosgate R500-1 amp
Stock Mids & Highs.
Budget Build, I spent about 330$ for the setup.
but its a crx, if you cant fart and do a 150 in a crx there is something wrong...
for 162.95 you can get yourself this
http://www.vminnovations.com/product_4093/Audiopipe_AP15001D_1500W_Mono_D_Amplifier.html
its 1 ohm stable. and people say it does rated.
Yo despues que las asomo... papa tu sabes como es que somos esto es flores pa los muertos y pa' mis enemigos plomo la 9 nunca se turba cuando bajan por la curva no es que yo no salga es que ustedes no entran pa la urba de humacao - Cosculluela.
For something that serious i would need to invest in a battery and cap for it.
Edited by Maroon97SL
Stock Mids & Highs.
Also keep in mind these subs are rated at 1000Watts peak, 350 RMS here is a little bit more detailed specs on them.
Watts MAX. Music Power 1000 Watts
Watts Nominal Power Handling 350 Watts
Frequency Response 18 ~ 600Hz
Sensitivity 87dB
Ohm Rating D2: (1 or 4 ohm) D4: (2 or 8 ohm)
Stock Mids & Highs.
can always keep the gains down, i dont think you need a cap, but i think ive seen users pull off this kind of wattage with a stock alternator, big 3 and a good agm battery in the rear. but its up to you not trying to force anything on you.
http://a248.e.akamai.net/pix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/2DVC_4-ohm_2ch.jpg
When i have my speakers ran like this, the amp cant power the subs.
Stock Mids & Highs.
Even the way the subs are wired right now the lights dim, i blew one 30 and two 25 amp fuses today... I need to figure this out on a some what budget. Im debating on just throwing my 12's back in there and selling these 10's.
Stock Mids & Highs.
ummm i dont know what you mean, the amp i suggested has 4 speaker inputs 2 -'s and 2 +'s, wire your subs in parallel that will give you a 2 ohm load from each sub, connect + and +'s to amp and - and -'s to amp inputs, then the amp will take those 2 ohm loads and internally they will be sort of like bridged(not the correct term but you kinda see what i mean) and you will have a 1 ohm load.
Wasn't the one you suggested a mono block? Is boss any good with their amps or am i wasting my money? Can i run dual 8ohm 12's off of that amp, its stable 600w @ 4ohms.
Stock Mids & Highs.
  • Who's Online   0 Members, 0 Anonymous, 1991 Guests (See full list)
