Ported Or Sealed?
I don't know which kind of box / size i should build. The subs are eclipse 87121.8 12" SVC 8-ohm. Right now i have them in a ported box and they cant hit the lows.
2000 White Saturn SL2
Kenwood KDC-248U Head Unit
1 Rockrod Fosgate HX2 punch DVC 12
1 Rockford Fosgate R500-1 amp
Stock Mids & Highs.
Budget Build, I spent about 330$ for the setup.
but its a crx, if you cant fart and do a 150 in a crx there is something wrong...
Build a custom box for it, if its in a prefab box most are tuned to like 45-60Hz, and that would be a reason you wouldnt be able to get the lows good.
¿ǝɯɐƃ ǝɥʇ
Yeah its prefab from car toys, small port like 2-3" x 16" maybe ( shared port ).
Stock Mids & Highs.
8 ohms? What amp are you running and I hope your amps not 1 ohm stable
Running a RF R500-1 its 325w rms @ 4 ohms
Stock Mids & Highs.
The amp is a mono block, this is how the subs are wired.
Stock Mids & Highs.
That amp is 2 ohm stable which gives you 500 watts at that load but your running them at 4 ohm which isn't the best way to get the most out of your amp unless that's what you wanted. I would go ported on the box with that power because ported is more efficient and sould hit lower then sealed. Hope that helps good luck
I thought ported took more power to run. I could be wrong.
98 Chevy Blazer 4 Door
Stock Everything
The New Setup
1 - Pioneer AVH-P5200DVD
1- Pioneer DEH-80PRS
2 - Blues Audio 5.25 Mids ( On the dash )
2 - Blues Audio BL8.0C Components ( In the front doors )
2 - Blues Audio BL8.0 Woofers ( In the rear doors )
1 - Linear Power 952 ( Dash )
1 - Linear Power 2202IQ Modified ( Components )
1 - Linear Power 3002 ( Rear Doors )
1 - SoundStream XBP-10 Processor
1 - SoundStream BX-20Z
2 - SoundStream DTR1.3400D
4 - RE Audio SX12D4
  • Who's Online   0 Members, 0 Anonymous, 2028 Guests (See full list)
