I got 2 of these babies up for grabs, their pretty much flawless. Nothing major.
Both amps work fine, and have alot of power.
$200 Shipped each amp.
$350 Shipped for both amps.
# High Speed Mosfet Power Supply
# Bi-Polar Japanese Sanken Output Devices
# Copper Rail PCB Architecture
# 24 dB Crossover Circuitry
# Fully Adjustable Low/High Pass Crossover
# High Pass Crossover: 50Hz - 500Hz
# Low Pass Crossover: 50Hz - 150Hz
# Bass Boost Equalization: 0-18db @ 45Hz
# Lucite Encapsulated Large 8 Gauge Terminals
# Soft Start Mute & Delay
# Adjustable Phase Control
# 4 Ohm RMS Power: 4 x 100 Watts @ 13.8 Volts
# 2 Ohm RMS Power: 4 x 125 Watts @ 13.8 Volts
# 4 Ohm Bridged RMS Power: 2 x 250 Watts @ 13.8 Volts
# Frequency Response: 10Hz - 40KHz
# Channel Seperation: >65 dB
# S/N Ratio: >100 db
# Damping Factor: >200 @ 100Hz
# Minimum THD: <0.01%
# Input Voltage: 200 mV - 8 Volts
# Dimensions: 15" x 9.25" x 2.5"
Edited by rival904
2004 Yellow F150 STX 4x4 Single Cab
2 Yellow DC Power 270SP's Alts
4(and counting) XS Power 6500's
4 DD3515s Supercharged
53cu.ft 4th order blowthrough
8 DD M1b's
6 Selenium 8's
2 Selenium ST350s
154.1 @ 41hz Legal Burp
Build Log
This topic is now closed to further replies.
