fox_racin4 Posted August 4, 2010 Report Share Posted August 4, 2010 well.. i cut my port down some becasue it was a slot port that bent over and it was causing some loading issues soo i took the bend off and im wondering what im tuned to box is 14T 36W 25D tripple baffeled ( if that helps) 6" slot port thats 17 3/4 long sub displacement id say it about .25 for each sub ( 2 12s) 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole Link to comment Share on other sites More sharing options...
fastfox89 Posted August 4, 2010 Report Share Posted August 4, 2010 well.. i cut my port down some becasue it was a slot port that bent over and it was causing some loading issues soo i took the bend off and im wondering what im tuned to box is 14T 36W 25D tripple baffeled ( if that helps) 6" slot port thats 17 3/4 long sub displacement id say it about .25 for each sub ( 2 12s) need to know length with and height for the port please sir Link to comment Share on other sites More sharing options...
pheint_1 Posted August 4, 2010 Report Share Posted August 4, 2010 here's what i got dont know if it helps, to me port area is a little on the high side but then again some subs do well with more port area per cu ft. tunings a tad high for most people's daily tastes, space for twelves seems optimal but then again this too can be sub dependant, but im pretty sure you know this just thought i'd express my thoughts, im prolly wrong lol im still a newb Yo despues que las asomo... papa tu sabes como es que somos esto es flores pa los muertos y pa' mis enemigos plomo la 9 nunca se turba cuando bajan por la curva no es que yo no salga es que ustedes no entran pa la urba de humacao - Cosculluela. Link to comment Share on other sites More sharing options...
fox_racin4 Posted August 4, 2010 Author Report Share Posted August 4, 2010 thats sounds a bit high to me, with the other piece of port i had ( was 5" ) it was tuned to 35 but i had to remove it becasue of loading problems i still get a bit of port noise when i run full power ( 6k ) 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole Link to comment Share on other sites More sharing options...
