Do i need a bigger fuse
ok so i have a 100amp fuse on my setup now but i just bought 2 more 15's and another amp...the amps i already have on it are a mono block alpine mrp-m300 being run at 2ohms with is 500w the second amp is also an alpine and its a 4 channel which has 50w x4channels and the amp ill be adding is a kenwood 2 channel and with a 170w x2 channels and will a 100amp fuse be enough to handle the addition of the third amp bc idk if they make a maxi-blade fuse bigger than a 100amps or can i just run a second run of power wire with a 60amp fuse off my battery and hook up the kenwood to it.
I hope someone can make sense out of this and help me out.
  • Who's Online   1 Member, 0 Anonymous, 1283 Guests (See full list)
