Where are you from? i can use cms and liters if you need :peepwall:
What kind of music you like? what car? what amplifier are you gonna use for that sub?
1. uhh dubstep and hiphop mostly.. no its in my room.. cms and liters easyer. either way good though. im in australia (:
im only useing a 290watt technics amp.. it distorts my subs/mids ( b4 had 3 10" subs and few mids ) for now...
looking at a 5.2 amp ( its got dual powered bass channels. both about 600watts each (: ) or something close to that...
Posted (edited)
this look alright?
Height - 15"
Width - 30"
Depth - 30"
port size of
13.5" high
6" wide
24" long ( 6" from the back )
which is 37hz.... ?
or with the bass port 5" wide instead of 6" itll be 34hz
would i hear a difference? between the 2?
should i go with a L ported or... L ported could go like 30hz ( with 5" wide port ) or 36hz with 6" sized port...
Edited by Liighthead
last post for the day lol
i built a box the other day... for my 10" pioneer its
24" H x 11 W x 17 D....
with a 3.5" wide tube... 10" long. 0.5" thick wood.
it says its 35hz... but thats a 3.5" square tube.. that bout rite 4 a 10" sub box?
thanks n take care all
